Will g37 wheels fit?
Wkg318GTP
What's up guys! I have a 02 gtp and I just bought some 19" factory g37 wheels and just need to know if I can make them fit? Here's the specs on them!
Front are 19x8.5 with a +43 offset tires are 225/45
rear are 19x9 with a +45 offset tires are 245/40
Im aware that I either have to make the center bore larger or use spacers. If I can get by with spacers then I'll go that route but if I need to take them to a machine shop for them to make the hole larger then I'll do that.
Any advice would be greatly appreciated!
I have 19x8 +40 I believe with 245/40/19s n no probs. but with 19x8.5 with the 45 offset it may be close..most you'd have to do is maybe roll the back fenders if anything. I'm lowered on ssc too though.
What is the center bore of the g37s?? Ours are 70.3 I believe..n I'm not sure about spacers..them obviously step the wheels out more and I'm thinking they'll be out enough..front could prob fit but idk about rears..bio is the man to ask about rims..I'm sure hell get you your def. answer
Then you need em bored out most likely..just type all this in google with Grand Prix at the end n you'll find everything you need.
bore out the wheels or run spacers. both are cheap. i'd vote for opening up the hub bore.
that size and offset should fit alright, but i don't know how i feel about running a staggered setup on purpose. heh. might need to roll the fenders, too.
I bent two of my 20 inch wheels the other day and I bought these for really cheap(350) with tires...not my first choice lol. I just hope it gives me the look I want!! Thanks again to everyone that helped out!
I don't know how to post pics lol! I will make phones calls in the morning to see how much to make bigger and that's when I'll decide which way to go. Everyone was very helpful!
