will G35 rims fit?
3R1CD4V15
Will stock g35 rims fit gp?
They are 5x114.3, which will work.
But the rim size and offsets are like this:
Front: 17"x7.5" +30mm offset
Rear: 17"x8" +33mm offset
I was wondering if that would work, or would the wheels stick out to far?
That should closer to the fender then stock. I'm pretty sure they'll work. Should look nice too.
Do you know any1 that ever ran a +30 offset on a 97-02 gp?
I really dont kno much about rims... lol
The offset also depends on the size of the rim. Someone on here is running 18x9's with a +30 perfectly fine. With the smaller 17x8/7.5 you should be fine running a +30.
The Pregen 5 spoke rims are 16x7 with a +24 offset iirc? And they work fine. I think you will be more then fine.
Ok, thanks for the info.
I was also reading somewhere that the hub bore is too small and you would need 10mm wheel spacers to use these wheels.
now with it sticking out another 10mm would that cause issues?
with those sizes id have to believe that youd be fine. however, you might have to roll your fenders if youre trying to run some beefy tires.
No they wont work unless you bore out the hub bore on the wheels or run some 10mm spacers.
Infiniti/nissan hubs are way smaller then ours.
as far as the offsets. Your fine,
