Even on a stock tune, unless your IATs hit 122* it wont pull any timing.
LOL. I just looked at the other BIN files i have. I was looking at the 97 bin I guess. LOL. 97s dont pull timing till 122*.
I'll reply more fully to everyone tomorrow but this one sticks out at me. If timing isn't pulled until 104 or 122* IAT - and that IAT is measured right behind the air filter - what is the "true" IAT post-blower? I dare say it's a whole lot higher.
A IAT sensor inside the LIM would allow for a more adaptive tune that could compensate for (1) the varying air intake temps which may be lowered by a CAI, (2) the heat added by the blower, and (3) any cooling effect that an intercooler has. Obviously when the latter heat soaks and IAT rises, the timing could naturally be yanked to prevent KR.
(pictures of IAT sensor drilled into LIM)
Later on, I relocated to the end of the intake by #1 cylinder.
I have about $60 into my cold air intake.
I have a phenolic intercooler that is cheaper than ZZP's aluminum one.
My intake air temperature are 20 above ambient. My heat soak temperature is way lower then most. What does it all mean????? I believe I will be faster run after run at the drag strip.
You should see my IAT
I'm running a blower S1X. I think Dan's running the NA oneAre you running the blower S1x or the NA S1x?
Real dumb "data" provided in that post too.
The iat sensor is the slowest depry sensor ever created. Its flat out designed to fudge the temps over time and the 10 seconds you are ripping (stagnant) air on a dyno isnt going to instantly drop the temps as measured by that slow as molasses sensor.
Bill, do you have a part number for the IAT sensor, wire you used (or a write up on both would be ideal?)
I'm listening... LOL
The stock GTO iat did the same thing. But someone found a different sensor that takes readings much more often.
It's possible. I haven't heard of anyone doing that on this platform though.was there not someone modifying the stock ones at one point for faster refresh rates? i could have sworn i had one on my car.
was it brian (reptile)?
