Where does this bolt go
the you never touched, stays open, theres two on the right side, leave that one open. its got a funky clip on it too, there used to be a foam cap over it, its long gone and not a issue.
your gonna need to put some mile son it so all systems show ready. you can see this in the t app or a hand held scanner, looking for "im readyness" once all them show ready, your clear to go to inspection.
Okay awesome, well I went and noticed my check engine light doesn't come on at all. Could that be the 1671 code?
when you turn the key to run all the dummy lights should come on. some times its the bulb went dead, a cluster swap would be easy enough if your not a soldering guy.
theres a bulb, its a little led thats soldered in the board. i dont know much more then that on the topic.
jy cluster should fix it tho.
Alright I'll go check out the junkyard in a little bit and get one. Thank you for your help on this journey lol
I hope so also, I'll be going to tomorrow so looks like I'll be doing the water deflector now instead
it maybe a very small bulb, but its still soldered in the board is is not? back lighting bulbs are the easy ones to change.
