yes it is and dex 6 is formulated for the newer trans's not the older ones like I have. Ive used dex 3 and i'm gonna stick with 3
The big question is how prevalent Dexron-VI will become in the service fill market, which trumps factory fill volumes. The fluid will become GM’s recommendation for service fill on all cars and light trucks, although not in time for owners manuals of some model year 2006 vehicles. Moreover, the automaker is already recommending Dexron-VI for service fill in existing vehicles, noting its compatibility with transmissions built before model year 2006. To encourage the switch, the company will cease to issue Dexron-III(H) licenses at the end of 2005, meaning all such licenses will expire by the end of 2006.
My trans was orginaly built for dex 2 from gm. And before I stick something in it the bottle has to say its compatible with dex 2 and dex 3. And the only mix I use is when I do my trans or any trans is one bottle of lucas trans fix and dex 3 fluid. If someone has a bottle of 6 in there hand can u tell me if it says it will work with a dex 2 trans
Lucas has saved 3 trans's for me i know from personal use it works
DEXRON®-VI can be used in any proportion in past model vehicles equipped with an automatic transmission/transaxle in place of DEXRON®-III (i.e. topping off the fluid in the event of a repair or fluid change). DEXRON®-VI is also compatible with any former version of DEXRON® for use in automatic transmissions/transaxles.
:th_popcorn:
That's what I was thinking. Who knew there could be drama with transmissions lol.
you havent been reading all of the trans related threads on here, have you.
I am using VI in my GTP...because it is the best. I liked what I read about it. think ZZP has an entire article on there website, or if not do a google search...
