10w 40 so in the chicago area in the summer would you recommend it?
weights can be misleading. for example mobil 1 5w30 is thicker then mobil 1 10w30
no its not lol 5w30 is like water compared to 10w30
5w50 mobil1 when i can get my hands on it, or 5w50 castrol syntec which is always available. - oil pressure never drops and its the the best range you can get for our cars, 5w30 is junk
im not gonna waste my time on an argument when there is rock solid proof on their website
dunno who your buying oil from cuz they are wrong. Just for ****s and giggles i googled some proof for you. Read the first couple short descriptions on the page.... 5w30 is thinner, hence, why you run it in winter because it flows better.
5w30 thicker than 10w30 - Google Search
How do you think you are going to get the volume to move around the engine? Pressure:th_thumbsup-wink:mobil 1 5w30 and a purolator pure one. BTW, oil volume is more important than pressure. Think about it for a second: when lubricating a drill bit for instance, do you want high pressure spray or high volume?
I would not run 20w50 it is to heavy..the only way I would run 20w50 would be at the track on a very hot day.. or in an engine that is worn out 5w30 or 10w30 is your best bet 5w30 winter 10w30 summer lucus ok..but I would rather put my money on a good synthetic instead !!
Ok good to know, so should I just switch to Castrol Sythetic or pony up for the RP? I dont mind the added cost I just want to know if its actual making a difference?
For the amount of miles you are driving, I would go with Amsoil Synthetic. It lasts up to 25,000 miles and is a very high quality synthetic.
Thanks for the suggestion, despite it being rated up to 25k how often would you change this oil? Stay on the 3k schedule?
