what model of gp's have the hud wires
Rather B Blown, you might have had a special ordered GP when it was new. As in, the original owner sat down in the dealership and checked the option boxes, and when it was specially built, they didnt install the HUD wiring. If youre the original owner, then im stumped
Yeah thats what im thinking my car was built to order, not one that was sitting on the lot already because im pretty sure that the cd player w/ equalizer, leather int, sunroof, and hud were all part of an option package and my car only has 2 of those
Rather B Blown, you might have had a special ordered GP when it was new. As in, the original owner sat down in the dealership and checked the option boxes, and when it was specially built, they didnt install the HUD wiring. If youre the original owner, then im stumped.
Other than that, to answer Soviets question, most all 97-98 had the DIC-HUD wiring, except for rare occurances.
Some 99's have the wiring, others dont. Its hit or miss.
2000+ do NOT have HUD or DIC wires in the dash. No matter what trim, option, or color GP it is, if it is a 00+ it will not have the wires. No need to make a detailed list.
And as mentioned earlier, DIC's are compatible as follows:
97's compatible with 97's only
98-02 are interchangeable
03's stay with 03's (because of the optional traction control, and the general differences of the 03 PCM.)
I guess he has finished the list or what ever it will be called.If no one wants to add anything,it may be made to be a sticky or just closed.Thanks for the input ,hope this has help a few people
In order to maintain validity of polling owners to create a list.... my 2003 GTP did not have a HUD installed, but did come with the wires/plugs, which is contrary to Super Sport's post....
Bottom line, it only takes a few minutes to check, just look in your car to see if you have the wires if you are interested in installing the HUD.
Ok then create a list. That is the first time I have heard of anything newer than a 2000 having wires in the dash. I dont know what the hell GM's concept is then.
I will change my theory to just check your car for the wires before ordering HUD/DIC to install.
Sorry to misinform.
I know after a certain point GM stopped putting the lights in the front doors... The wiring just disappeared but the reflectors stayed the same.
Yet under the hood I have a connector for an A.I.R. pump but no pump.
There really seems to be no method to this madness.
So how would I check if my 2000 GT 4 door has the wiring or plugs?
And is it pretty hard to install? Would really like to get a HUD into my GT, think it looks badass. Oh and how much can I expect this to set me back?
You can install both without the wiring, but youll be doing a lot of splicing. I installed my DIC without plugs.
But to check, just remove the bezel that goes around your radio and gauges, and look for a spare plug behind the DIC, and check behind the gauge cluster and in the opening where the HUD dimmer switch would go and there should be a empty switch laying there.
