What did you do to your Car today?
Status
Not open for further replies.
Corrected the tire size back to stock. While i am running slightly taller tires... it's not enough to bother with the change. Plus using the Miata calculator and the proper sizes.. somehow I ended up with the incorrect size and (don't tell Brandon) but some of those pics I sent him may not have been entirely accurate.
Picked up my car after yet another visit at the shop. Rack and Pinion part installed last weekend was bad. Had to be replaced, no charge!
Today I glued the roof rails on in a more permanent fashion. With urethane instead of the weak double backed tape I had used.
You should have used 3M tape, I used the 3/4" stuff we have at work and you can rock the car with them, 1 whole piece front to back I think you would break them if you just tried to pry them off. It was just as wide as the base so it fills the whole area with stickiness.
I used the good stuff, 3M double sided automotive tape. It didn't adhere at all. Trust and believe I did clean all surfaces beforehand. So for me urethane was a far better solution. =]
Status
