What did you do to your Car today?
Status
Not open for further replies.
Hey scotty, didn't you say a while back about an ebay seller that would make you any kind of harness you want? I need like whatever connector for the WSS at the bearing (9006?) and like 2 feet of wire off it. I'm going fix this god forsaken ABS light even if I have to rewire the damn thing to the EBTCM.
Sent from the Milky Way
I found it lol, damn its expensive. I might be better off just making the pigtail myself with a new connector and some wire. I have a spare connector in my car just have to re pin it.
that would also work out well.
they look to have gone up in price a few bucks. my maf and ait pig tails came to 22 ish shipped 4 years ago.
no idea, theres alway the junk yard, then re pin that plug or just use it and add more wire to it if need be. one side has a plug iirc, the other dont, not sure what side your after. d/s has the abs plug at the end of the harness iirc.
Passanger side, I want to avoid adding more wire as my solder job quality varies from awesome to butt connectors would be better. I'll repin and give it a shot, when I soldered I didnt keep cutting till I got clean wire because I was getting pissed off at. Round 2 will be a better job. I just hole I don't have to try to solder up in like the center of the subframe lol.
if it comes to it take them out of the wire loom by the balancer. then remove enough so you can solder them in the open with any luck.
if you use butt connectors they still work best with clean wire. you can always add shrink tubes over the butt pos things to make them more weather tight.
Butt connectors were a reference to how ****ty my soldering can be lol. I should have took a pic of it. I blame my soldering iron tho. I need to pickup some shrink tubing and some self adjusting wire strippers. I had like 12ft of it from my friends dad that he stole from work and I left it when I moved.
HF is 2.5 hours away. Might see if I can get it cheap on amazon. Im in no rush, no TC or ABS really isn't a bad thing lol.
Amazon seems to have good prices, gonna spend more than the ebay pigtail but at least I'll get a tool out of it and other crap. I just need to figure out what gauge wire I need looks like 18 or 16.
Status
