DirtDog
I'm sure it's better than nothing , right?
Sent from my SGH-T989 using Tapatalk
I'm just giving ya a hard time man
What did I do? Trick question, nothing. It's been sitting in the below freezing temps since Tuesday. It'd better start tomorrow morning for work, it's going to be 2° (fahrenheit btw). -17°F for the wind chill. I'm thinking of doing a cold start video, it would be the coldest I've ever started it.
The temp alone this morning was like -10, plus windchill and you're at like -25-30. My car sat for 9 hours at work today with temps never reaching above 0, it starts kinda hard. Misses a few times, takes 3-4 attempts sometimes haha.
These temperature barriers are making it hard for me to communicate.... Haha
This morning, I started mine at -26 C, which is -15 F, and that's without windchill. Coldest start I've ever done was -34 C last week (-29 F) without windchill. She started but complained a lot afterward. Don't know the specifics of the windchill, but it was probably around -40 with it. (F and C same in this case).
you got a block heater? if not get one. your oil must be like glue at first start lol
Must crank slow. That's what I'd think since my engine always fires right up as long as it's able to crank fast enough. I have a new battery so my hopes are high.
Yeah or at least run synthetic oil. Conventional would be like honey.
I'm still running 10w30 from summer/fall........LOL, I havent needed the oil change yet. I'm about 200 miles away, so I know the heavy oil isnt a huge help but I like to blame being modded and running 10-15% ethonal gas.
My battery is kinda odd, its never been what you call spunky but it'll aways crank at a steady pace. It's got like 900 somthing CCA at 70º and 780 at 32º. With the block heater plugged in it'll fire right off on the tap of the key most times.
I run 10w-30 all year long, synthetic so it's not hard on cold starts or anything, so no need for 5w-30. But I only change my oil like every 9 months lol. That's under 3k miles for me. But it doesn't make any abnormal noises even on my coldest start to date which was 13°F. Although the 3800 in general has a very unique sound at cold startup.
This is true.10w-30 synthetic has the same viscosity as 10w-30 non-synthetic.
This is also true. What you don't seem to understand is that the term "viscosity" is not the same as the term "flow rate". Synthetic oils have a better flow rate at lower temperatures than conventional oils. (while still being the same viscosity) Viscosity does affect flow rate(which is why you suggest running a thinner oil), but flow rate doesn't affect viscosity(which is where you're confused). Hope that clears that up for you.They both have the viscosity of sae10 weight oil at 0 degrees(w for winter). The both have the same viscosity as sae30 oil at 212 degrees.
