water?
helivancleef
hi guys,
got a 05 gp, sounds like water is splattering from side to side when i accelarate or steer. nothing is wet inside, floor dry, ac drain is free too. any ideas what that could be?
typically thats air in the heater core. hows your heat working?
take the 2 heater hoses off the alt bracket, then flush with a garden hose through either hose till a full stream of water comes out the other hose, put the hoses back on.
heat works, is not very hot though, let the heat run for 30 min but its not gone.
shouldnt the air come out from the water pressure when the heater is used?
Heli
make sure it's filled up all the way. Back flush the heater core and then bleed the air out of the system.
the way your heat works is theres a small radiator in the dash coolant passes through it, when you turn the blower fan on, it pulls the hot air from the rad. if this rad/heater core has air in it theres not going to be good heat, if any at all.
flush your core like i posted above. its air bound for sure.
