Scottydoggs
Killa Bee
can u rewire the pump to a push button switch mounted somewhere by your steering column? and then whem you press it only the pump would turn on the you would have to turn the factory switch to make the wipers turn on, correct?
Honstly im cheap and i just want it to spray, dont care how lol
that could be done real easy like. you just need to cut the wires at the plug, (leave 4 or 5 inches of wire on the plug end) and run the wires from the plugs pig tail to power and a a switch, do put a fuse on the power line.
