I was wondering if I can run a single turbo with my supercharger.
It wont be too long before i go sts twincharged
His name is blackgs
That would be me! :th_thumbsup-wink:
I have a Stattama kit from zzp. I am running a T72 turbo with the supercharger (3.4 pulley on the s/c right now). The supercharger will give power off the line up to about 6psi, and then it will bypass and the turbo takes over. For the street, this is a nice setup. I am limited to 15psi right now because I am still in the process of installing a second W/A intercooler. After that gets done, I hope to push closer to 20psi. Still, at 15psi and 15 degrees of timing, this thing moves. I ran the 12.69 with stock heads, stock cam, and stock trans. I have since upgraded the trans to 3.29 with 1" chain, but haven't made it back to the track.
There are a few other people running twin-charged as well. The real advantage to twin-charge is that you can run a bigger turbo like a 70 or 72, and not have lag.
Here's a pic of my setup right after I installed: http://i20.photobucket.com/albums/b230/rcarboni/2000%20Regal%20GS/Turbo/TwinCharged.jpg
Looks sweet. I wanted to keep the s/c til the turbo spooled up. but is it worth it(money wise) or would it jus be better to dump the s/c and jus go with the turbo?
BlackGS.... did you have to upgrade your injectors or anything for 15psi?
If you run with a smaller turbo like a 61 or 66, you won't need the supercharger to help it spool. There is very little lag with these turbos, and they are easily going to get you 400whp if setup right.
whats the max boost that the 66 can push? Because my goal is to get into the mid-low 10's within a year or 2. Would the z7 kit work or would I be better off with the stattama kit.
Talk to Matt or Zooomer at zzp for info on twin-charging vs. single turbo. I think Zooomer went high 9's or low 10's in the twin-charged GTP, and they had the Impala that went low 10's with just a T67. Either way, you can make 10's at the track with the right cam, tuning, etc., if you can launch!
