DaytonaGTP500
hey guys been looking around a lil and nothing really solid yet but my current build list is
l67 block/crank
st4 cam
stage 3 zzp heads with turbo valves, PAC 150lb springs, felpro perma-torque headgaskets, arp studs
l26 intake with hv3, stock 00 l67 throttle body
bullseye s259et turbo, tial 38mm wastegate, big a$$ intercooler
front and rear logs, z7 crossover, 3" dp/exhaust with electric dump
e85, #80 injectors, dual fuel pump from lonnies performance
Fingers crossed for 550-600whp with good dyno tune...
I'm sure I'm forgetting somthing too but obviously not coming up with it right now lol. Anyways block and stuff is at machine shop right now and he's REALLY stressing pistons and rods soo... I'm liking the 4340 h-beam rods and je pistons from zzp but am COMPLETELY lost on what I should go with for compression ratio? I know lower compression can handle more boost n all that but I also know that's not ALWAYS the right answer so I was hoping for some input from everybody?..
Also just so no one says you best get yourself a good trans n blahh blahh... I got it!!!! lol, talked with Dave at triple edge(who is amazing to work with by the way) and we built a DIY setup with a 3200 stall converter from precision n that's already built waiting for the engine lol.... Thanks guys!!!!!
l67 block/crank
st4 cam
