sdavis11b
I came to the conclusion that I had some sort of tranny fluid leak the other day when I heard my transmission whining due to low fluid. So I did what everyone does, jack the car up, clean the underside with Brake Cleaner, start it up and wait. After about 10 minutes there it was.
Leaking out of what seemed to be the heater core, dripping all the way down the firewall, then onto this Brake line:
Never seen anything like it. So out of curiosity, I checked the radiator and there it was, strawberry milkshake madness:
Having never seen this problem before, and after doing some research, it seems that the "transmission cooler" inside the radiator is damaged or broken. What are the next steps I should take to solve this problem?
Thanks
Thanks
