Neg means your fueling is rich and that the computer is pulling fuel. obviously if the trims are positive, then the pcm is adding fuel to compensate for a lean condition.
if trims are +15% then in theory you can add 15% to your maf and be in balance. this is not always the case though... small steps. if i saw 15% i would do a 10% and test again.
fubar569: one thing that may justify the aeroforce over an app for droid is the refresh rate. i bought a ScanGauge II as a replacement for my 1st gen aeroforce when the screen went out... big mistake. even at the highest refresh it cant even compare to the aeroforce's refresh. i could have KR and never see it! the gauge style scaners are great as an addition to a full data logger
My torque tells me I'm running -30* of timing, 9* of KR and 5.5 psi of boost. I don't think its right. Because if that was right I am pretty sure my engine would have gone boom by now.
Why do you have to be rude and assume that its an error between the user and the device rather than an issue with the application?
Let me know when you want to stop playing with toys.
How fast does it scan?
Testing on LS1 cars has shown a scan rate of 330-350mS for 10 parameters (30 parameters per second), down to 50-70mS for a single parameter (20 times a second). The fewer parameters you select, the faster the scan time is. During wide-open-throttle (WOT), the response time is about 20% slower because the car’s computer is busy and doesn’t respond as quickly to scan tool requests.
What are the basic Bluetooth® data rate specs?
Bluetooth has the capability to enable both voice and data (depending on the specific Bluetooth profiles included on the device). The voice channels typically operate at 64 kbit/s. The Bluetooth 1.0 data rates include an asymmetric data rate (one way) of 721 kbit/s (while permitting 57.6 kbit/s in the return direction); and a symmetric data rate of 432.6 kbit/s.
97's.
