Top of the struts under hood
Mine did the same thing. I heard about the pogo washers and made my own.My shocks were good at the time too.I used some actual washers from rural king.Doesnt look 2 bad ether.
All that is needed is thicker washer under the factory cup. You can remover the factory cup by romoving the center nut, and install a thicker washer under the factory cup to tighten up on the bushing. You can actually adjust your ride by how thick the washer is and is putting pressure on the bushing.
AN impact wrench mackes removing and reinstalling the center nut a sinch.
