tire and suspension suggestions
How do agx's lower a car? i don't recall them Having a lowered spring perch or shorter rod. The zzp's gave a nice ride height on my gtp they were excel g's with there lowering spring combo
I had thought that ZZP sold the AGX's with a lowering spring, but after viewing the site, they dont.
ZZP's springs say they lower 1.2 inches, but I doubt they will lower it much more than 1 inch. Maybe after a year you might see the 1.2 drop.
it says on the site they come with ssc lowering springs and kyb agx's struts?
what else would drop me lower then these i wanna be able to raise the car a little for winter driving so i need something adjustable
they do either agx's or excel-g's (GR-2's)
ZZPerformance - Drop in Strut/Spring Combo #ZZ-DRPSTSP
i got about the advertised drop on my GTP, very nice package.
AGX's only adjustment is damper firmness nothing else related to height. you need coilovers for what youre ddescribing
you wont be able to raise the car for winter. you sort of could with coils, but i doubt it'd work out like you plan. only other option i can think of would be slamming it on air bags. likewise, i do just fine in chicago winters dropped on ssc's.
how much is the option of airbags havent looked into it much. what would a good setup be for coil overs? i might just say screw it and lower it on them and have to deal with it during the winter.
Last time I checked bags were upwards of $2k+
Vendors coilovers are $1k+ if you go with gr2 or pay more for agx or you can make your own if your willing to spend the money and do your research.
It's probably cheaper just to lower the car on SSC and call it a day.
Coilovers vary if you want that route can very cheap. 175bucks for the front if you're using your oem shocks. You can always go kyb excel g or agx or konis but this require a little more fab work I have a a little over 400 for my setup.
