Chadgervais
Former GP Owner
Stock GM 195 thermostat: is 195 the "full open" temperature or the "start to open" temperature? Reason I ask is my operating temp when at speed. I know the fans dont kick until well over 200, but when im cruising the temp (according to my OBD reader) goes up to 190 then starts to fall back, sometimes as low as 181 if its cold out and the heat is on full blast. On the highway, heat on or off, it stays between 186 and 190.
Im just wondering if the previous owner didnt slap a 180 in there, because i thought that the rated temperature was the point it started to open. If that be the case, it would make sense that by 190 its open enough to circulate coolant efficiently.
