The Panda- Pretty Much a Racekar
Re: The Panda- Sad Adventures
I have a 340lph pump from TRE. Will also be running 60lb injectors. From everything I've read you either have to switch to a venturi setup, or, modify the canister. I'll likely mod the canister for now.. but I haven't gotten into it and don't even know what's going to be involved to get it to work.
I'll be following if you do that. I need some options, maxing my pump and injectors. 130% duty cycle lol
I thought for you to have lope you had to run the 105's because those were too small before? Or is it a unsuspected change I don't know about?
Here's the engine mostly finished.* Just have to finish the SC and LIM.* I have an electric waterpump I need to throw on too.
GXP rear brakes are a success :)
Headlights are finished, putting the lens on tonight hopefully, I'm digging the halos and fully black housings.
Your LIM looks like it is on backwards.
Thanks guys, I appreciate it!
Zach, they're still gold like before, just way cleaner looking. They're not Apollo shrouds, but I'm not sure what they are.
And. I may, or may not have shortened struts...
Thank you for painting the motor a reasonable color. That gold always made me puke, was never my color.
Seems like the sad adventure is done, the reborn Panda is almost ready, right?
Despite what Bill says, the Gold was the shiz.
Looks great.
Maybe it's the light, but the snout doesn't look polished and the case is...?
Regardless it looks good man.
