No, I have been emailing Tim at zzp and he suggested 42# injectors, hot wire, voltage booster, new filter. He said as long as I didn't plan on running any lower than a 3.2 pulley I should be fine on that setup on a stock tune. I got a good deal on injectors on here so that's why I have decided to go this route. Although I think eventually I will go 60's with a tune. Probably about the same time I go intercooled.Did you order a tuner
No, but I fully understand that when/if I run into an issue with this setup I will remember you suggested a tuner. And I will eventually buy one before I take this any further.still no tuner?
Well that is exactly what I will be doing, I don't know if dude thought I wouldn't look but I went to check out the black car today, junk! Towers are gone and the rockers! Why tell me it's a clean car! I will be finding a way to fix my silver coupe at least I know it's rust freeWhy not get under the front of the silver car and take a look and take measurements to see if you can find the problem with the wheel sticking out?
