HERES MORE!
Onto brake calipers...
Stock front calipers:
63.5 mm bore.
for 1 mm stroke,
3168.20 cubic mm
04+ GP calipers are the same.
06+ imp
45 mm bore x2
1 mm stroke x2
1591.07 cubic mm x 2
total 3 182.14 cubic mm
Thus nearly the same.
Simply a larger pad, more pots for more even force distribution.
Now lets look at F body calipers:
Also a 45 mm bore... Same numbers as the 06 imp calipers.
Now lets look at C5 calipers, non Z51 or Z06.
Edit: turns out Z51 brake package used the same calipers, different brackets, and a 13.19" rotor versus a 12.8" rotor. At least in the front.
40.5 mm bore x2
for 1 mm stroke x 2
1288.77 cubic mm x2
Total 2 577.53 cubic mm
3168.20 - 2577.53 = 590.67
590.67/3168.20 = 18.6% smaller.
More fun:
Master cylinder bore is 1" so 25.4 mm.
You apply 1" of pedal, 25.4 mm.
thats 12 875.55 cubic mm of displacement.
stock calipers are 63.5 mm bore.
V=pi*R^2*h
thus both front calipers must move a combined 3.84 mm.
Thus one caliper moves 1.92 mm for 1" of applied pressure.
Now onto rotors....
http://stoptech.com/tech_info/formulas _vehicle_braking_dynamics.pdf
Tw = Ps x Ap x μ x 2 x Re
lets assume 1200 Psi (8273708.75 pascals) is being applied to the caliper.
A= 2Pi*r
Ap = 2*Pi*31.75
Ap = 199.49 mm^2 (0.00019949 m^2)
Lets assume a decent mu of 0.5
Our '12 inch' rotors are 303 mm (0.303 m)
Our '11 inch' rotors are 278 mm (0.278 m)
04+ are 297 mm (0.297 m)
Stock:
Tw = 8273708.75 Pa*0.00019949 m^2*0.5*2*0.278 m
Tw = 458.85 joules
Stock calipers w/12" rotors:
Tw = 8273708.75 Pa*0.00019949 m^2*0.5*2*0.303 m
Tw = 500.11 joules 9% increase
Tw = 500.11 N*m = 368.86 ft lbs
04+
Tw = 8273708.75 Pa*0.00019949 m^2*0.5*2*0.297 m
Tw = 492.01 joules
Tw = 492.01 N*m
F body calipers w/12" rotors:
Ap = 282.74 mm^2 (0.00028274 m^2)
Tw = 8273708.75 Pa*0.00028274 m^2*0.5*2*0.303 m
Tw = 708.81 joules 55% increase
Tw = 708.81 N*m = 522.79 ft lbs
C5/C6 calipers w/12" rotors:
Ap = 254.47 mm^2 (0.00025447 m^2)
Tw = 8273708.75 Pa*0.00025447 m^2*0.5*0.303 m
Tw = 637.94 joules 39% increase
Tw = 637.94 N*m = 470.52 ft lbs.
GXP Fronts
Tw = 8273708.75 Pa*0.00028274 m^2*0.5*2*0.323 m
Tw = 755.60 joules
Earlier guess of an increase in front brake "capacity" of ~29% with sportier tires suggests we should have 29% more front brake power.
Seems in this comparison the F bodies are a terrible choice and the C5's are better, but not ideal.
Again, all going on some assumptions which we do not know the answers to.
All bore information based on sheets like the following from centric via rock auto:
http://www.rockauto.com/catalog/moreinfo.php?pk=2052622
Also the incorrect Re's were used because its kinda difficult to calculate the radius of clamping when its not just one point.
