HEVEYMETIL
ok - moar fun.
Has anyone tried to run GTO brakes up front??
Ok so 90% front bias seems a bit much, even if we have a soft suspension. This would be even more evident with a stiffer suspension (coughdrunkiecough) Every time you slam on the brakes the fronts always lock up first. would it be beneficial for stopping distance to upgrade the rears to GXP only? IMO if the stock brakes can lock up the tires, why do you need stronger brakes? unless you are road racing and the heat becomes an issue.
Its not just about stronger, its about moving out from the center point of rotation. Its like my analogy with the door, its easier to push a door open the further you are from the center pivot point.
My brakes are overkill and I know it, but it does have a huge difference in stopping, just because you lock the brakes up doesn't mean your stopping can't improve. I think the front GXP upgrade is more then enough as is with the right pads and rotors, as for the rear GXP brakes, No...lets face it these cars are not high performance in the handling department. They tend to suck wind at it.
The stock brakes are enough to beat the maximum distance allowed by US Government regulations for stopping, so yes the stock brakes are really enough, but there are plenty of options for all of us who would like better braking cause the bare minimum just isn't acceptable sometimes.
Its all in a matter of what you really want. You can do a nice set of rotors and pads on stock brakes with SS lines and that should be enough of an improvement that you will feel.
hmm if you lock up all 4 wheels at the same time wouldnt that put your car into a slide, and sliding isnt stopping right?
