Yes, you only need the four rubber boots for the new brackets. All the old bolts transfer over. You can use the old ones, but good luck getting them out of the brackets intact. Most parts stores will have them in stock if you need them. I think I grabbed mine at Autozone.
[FRObNT KIT] [BLACK CHROME] Slotted & Drilled Brake Rotors AND Max Ceramic Pads | eBay
These will work for the Fbody conversion correct? There 06 impala rotors.
If your using fbody calipers just buy a rotor/pad set for a LS fbody. Then you dont have to go out and buy fbody pads still and you wont have a set of pads laying around that dont fit anything
LOL Yes... majorly different bolt pattern.
5x120 I think
vs our 5x115/114.3(mustang)
Those will work, but the rotors/pads will likely be cheaper quality. Most users have found the R1 Concepts to be a good rotor, and they have a Ebay store with good deals too.
5x120 I think
As long as you have banjo bolt with that kit no
You can not reuse the grand Prix slider =/ went to install today and can't because slider does not fit. Now I have to wait for Napa to get them in. I swear to god if the rotors don't fit and I listened to everyone here I'm gonna freak
