The 130 dollar 2002 GTP 40th Anv Edition
Still a lot to do but it will do for now! This is my first fiberglass/bondo job so I'm happy with it!
Last layer of bondo trying to fill some gaps
After it was sanded
Then I put a black base coat
Then I put on the closest color I had to factory that way laying around (this is why my Bose coat was black)
Now I'm waiting for my paint matched textured paint to come in!
Ehh it leaves me with something to be desired but it will do for now. Next I'm going to move the a/c controls down. Eliminate the ash try to make room and put the bar across, between a/c and heater then make under the ax curve down just like the ash tray did.
I found this...
I scooped the cylinder out with my inspection cam no chipped piston ftw.. My guess is be for my fuel pump went out it was running supper lean. And it melted that plug... Number 4. Or this is the injector that was right beside the melted one. It might be bad. I cleared the misfire code and put a new plug in it and I got po171 system to lean... Can not find any vac leaks though. So maybe the injector is bad... *shrugs* ill hook it up to the scanner and find out. Probably replace injectors also...
Then I buffed it!
Well the hood anyways lol
I LOVE the dash cover, looks very clean. Once you get it color matched/textured it will be phenomenal :th_thumbsup-wink:
Very little damage to the bumper cover. But the vent for the trunk is a little banged up and the plastic skirt... Life goes on just something else to fix
Oh **** that. What a chode.
I would be irate. Should've told his ass to go panhandle on the street until he got the money.
It doesn't matter how much the car is worth or how much it cost, that is grimey in every sense of the word.
