Booba5185
Nope, I had oscillating RPM going up hill\underslight load, disconnecting the TCC PWM solenoid stopped the behavior, but cost my 5 MPG in town (10MPG with it off, 15 with it on...I live in a SMALL town).Were you getting a code for the TCC? Is that why you pulled the pin?
The Raybestos is the bottom friction (with the wider patches), should I use it in the inside (closer to the hub) or the other one on the inside and the Raybestos on the outside (closer to the valve body)? Doesn't matter? lolyes you can... to a degree a friction is a friction.
