Sunroof
Scottydoggs the glass is the same for FACTORY grand prixs 97-08 but not sure for the asc,when you go to measure will you take a picture of it open so we can compare please
Sent from my SAMSUNG-SGH-I337 using Tapatalk
pics.
looks like its 18 from front to back and 32 1/4 wide.
shot down the track, not much to see :/
with the back raised from inside, all i see are 2 screws on each side, these pics are of the rear one. it was dark under the building and i was not sure how or if they would come out.
theres one more closer to the front.
I know where the little screws go in look a little different but tracks and that flappy thing in front when it's open looks the same
the edge of the rubber is the edge of the glass. on mine any ways, you can see its gone from the open pic and the track shot.
Would the metal on the roof be folded down on the sides like yours or would it be cut like with a plasma cutter, seems like the plastic is hard to get off but looks like it's just sitting in there
pretty sure it would be cut clean around the roof. but not 100% sure.
id have to look at mine closer to see if its the body rolled in like that.
So if it's just clean a factory one wouldn't work right anyway, the company has to make replacement parts cause if something breaks people are screwed, I can't find the button assembly anywhere
Ok the plastic around the sunroof goes down in there like the rolled metal, I guess it will be a summer time project, sine the motor is running it's just the tracks are screwed up
UPDATE-i got a around to removing what they called a sunroof,its so screwed up,the original headliner is screwed up there with self tapping screws,they just cut around it and used black duck tape to tape the wires up,looks like a sh$%&Y job to me,the headliner consisted of glueing a piece of fabric to the original headliner around the outside edges,there was a piece of board covering the sunroof and it was glued to it also,that's it other parts were left hanging,I'm left clueless on what to do,these asc sunroofs seem to be rare,can't even find a dome light,if they would have repaired it they would had to tear the fabric down also,I'm calling Monday to see what a new headliner will run or try to fabricate one or get a custom one built,any ideas??,I'll have pics shortly
you take your headliner out, rip the material off, sand the foam off, then buy new material of your choice from a local sewing shop. use rubber cement in a spay can, set the new headliner on the board, fold it 1/2 back, then spray the new material and the board, let dry, roll it on, press it out, repeat for the other 1/2, then spray the edges and fold them over a inch.
new headliner.
The thing is there really no headliner,I'll get a pic in a few they just glued it to the old headliner and can't take it down
