What about BC Racing? They make a set that would be nearly bolt-on for our cars, they cost $1250-ish. I've heard tons of great things about BCR from WRX to Supra guys. Surely just about anything would be better than AGX's (or even GXP bilesteins) and adjusting them at the spring, no?
Well what do you deem better? To me, better would start with the spring rate. You'd pick one for the car, and the roads you drive on. Next and most importantly is the damping to suit both the spring rate and the car. The biggest struggle is getting there. Most products have damping that is set, or just have adjustable rebound. The issue there is, too much rebound means the car will jack down and run out stroke quicker. The other issue is you cannot adjust the compression to adjust for the change in spring rate. Even KW V3s don't let you adjust high speed compression. Nor will they revalve them. They want you to buy clubsports at that point.
It seems many actually enjoy excessive rebound, as it makes the car feel sporty. I'm not a fan though. The car will make every tiny bump feel like a larger one, and the car will crash into the large bumps. The issue I have is the balance between high and low speed damping. My Koni Sports did not have enough low speed damping to control the vehicle over gradual changes. Meanwhile there was too much high speed damping at almost any level of adjustment.
Next struggle is the monotube vs twin tube debate. Really it shouldn't be one, monotubes are better for performance, but cost more. They also require an external canister once you require a certain level of adjustability. This adds weight, and cost. There is also the quality of the valves, seals, top hats (the spherical bearing), paint, the tube itself, the springs, sleeves, adjustable nut, etc.
My super limited experience continues to teach me, cheaper products will fail before the more expensive ones and leave you disappointed even while they are functioning to the manufacturer's specifications.
One such example is the Koni Sport shocks I installed last May. The front right shock out of the box never seemed to match the damping of the left. I pulled them off last week only to find a blown top oil seal and the piston would not extend after being compressed. Not impressed especially considering I put 10 000 KM on the vehicle in that time. To be fair, my assessment of the Koni damping is likely due to the mismatch between the two front shock inserts. On the other hand, Koni is known for having terrible quality control on their valving, and using less than stellar quality paint. I did spend a fair amount of time playing with the damping out front to make the two match by driving over the same bump at the same speed and trying to discern which setting worked best.
The only thing garbage about our coilovers is the top hats....really if we had that adjustability and function of a pillow ball bearing mount it would be a lot better.
I'd be willing to bet the most important place to spend your money, after spring rate, is in valving.
