99GTPzilla
Can the stock intake tube be used with a K&N filter on the end? I bought the 1foot intake tube from ZZP along with a filter but this tube is kind of a p.o.s.... If not then I gotta run to autozone and get 2 coupler reducers..
take the filter and put it right on the throttle body and be done with it.
I would say this:
ZZ Performance
I think you also needed to select the "add aluminum ring" option when you ordered the tube, i believe it's for the filter side. Maybe they can ship you only that.
I used 4" dryer tube and some pvc pieces... it's ugly but works.
Yeah looks like I need to find a way to get that aluminum ring or make my own or something...
Kinda sucks I wanted this thing installed today
Just put it directly to the TB as everybody says, it's practically the same and put the tube in once you get the rest of the pieces.
It's not like you're gonna gain 30 hp out of it. Do it for the SC whine hehe.
it won't affect to have the IAT outside. It is more hot right at the TB, but you get more flow. It won't harm the filter either. There's a sticky which i suppose you've already seen in this same section about open cone vs. fenderwell intakes.
That's an old discussion here and the sticky thread pretty much sums it up. It's always the Open cone VS. cold air intake argument.
check that thread out. it has some dyno info with both type of setups.
do what you want. its personal preference.
