Okay my friends, my adventure is over. Sven, your record is intact, it actually took me almost 5 hours and three beers to remove the fan and rad. I took my time so as to not break too much stuff. I only had to break a couple of the clips that hold the wiring to the fan, so I think I did pretty good. I ended up taking out the battery and pan along with the air filter box. The bottom rad hose was somewhat difficult as the squeeze clips were pointing down and in my infinite wisdom I parked too close to the curb to get a jack under the car to get under it. Lesson learned. In any event, I replaced all of the squeeze clips with screw clips for easy removal in the future. Next day I reassembled everything all the time hoping it was the coolant rad with the leak and not the other one. I also found out that one side of my fan did not have a heat shield. The take aways:
1. Its almost impossible to reclip the fans together on both sides, so I got one side on and screwed the other one in tightly.
2. Always make sure you have ALL your needed tools before disassembly, I found that out the hard way. My kingdom for a 3/4 crescent wrench to remove the tranny lines as the "quick" disconnect wasn't quick at all. Had to use a small adjustable, got them off with only minor damage to my knuckles.
3. Always remember the fan comes out at an angle and goes back in at an angle. Straight up and out is IMPOSSIBLE.
4. After reassembly, torque the motor mounts BEFORE starting the car. That's a feeling that no noob should go thru.
5. Don't sweat the little things. So what I had two bolts left over after everything was done. Its running fine so I figure GM just included two extra ones just in case.
The upside, the car runs fine now, no hissing, no steam, and the photo above was the hottest it ran since the replacement. Mostly it runs just below the line.
Lastly, what's you guys opinion on Seafoam? I'm thinking about using it to see if I can quite a lifter noise I hear. (If that's a lifter noise)
