that was a blown engine he used as an example as to why it was dead, all that coolant under the upper intake killed that engine.
the engine stays in the car, its a 3 hour job if its your first time, its about a 100 bucks in parts to do it yourself. or up $600 at a shop.
this is how far it has to get torn down too. clean up the matting surfaces of the head, and the lim, new gaskets put the lim back on then the upper intake. the fuel rail, then the wire harness.
to plug them holes will cost you like 20 bucks for a tap and the plugs. for the piece of mind that it will never eat coolant again. or chance engine failure. its easy enough to do.
its just nuts and bolts, take pics along the way, bag your bolts, label the bag. its not hard.
and this can be done in your parking spot, if it takes you longer then a day shut the hood go home. parts into the trunk. i do 90% of my work in a public parking lot, im also stuck with apt living. it sucks, but it is what it is.
and im no kid, lol the cars from the 80's were worse then this is. it was the 60's and 70's that were cake to work on.
and if your stuck there always someone around here to help guide you through the job.
and back together, mine is super charged but its the same job.
