Some more top swap questions! Yay!
Yeah it happened to me to let it drain out. I used some rtv around the threads and I've never had a problem.
Sent from my SM-G920V using Tapatalk
Umm kinda looks like mine how I had coolant in the intake except mine was filled to the top with dex cool yours looks stained
Lol well i had the lim and everything off just a couple thousand miles ago so thats why it doesnt look to bad haha
Sent from my LG-D851 using Tapatalk
I havent had any trouble with coolant dissapearing and no it didnt look worse it was just filled with coolant
There's not suppose to be any coolant in there only air that's bad that's exactly how my motor hydro locked and bent that rod I showed you.... when I took my motor apart the bearings had water spots on them and it ruins them.
When i took it apart last time i asked everyone on here and they said it was normal to have fluid in there
Everyone? No its the intake there's no coolant that should run through there air only. That's the main problem with N/A cars because the coolant passage that most people plug off with "dimes" I guess leak into the intake when the plastic upper plenum or intake takes a **** that's why there are revised upper plenums now.
I changed the lim gasket just because i heard it was a common problem. When i did that succesfully is when i said screw it. Top swap
Yea when that plastic pos **** gasket goes then you get coolant running through the intake down in your motors big problem with N/A cars there's a write up on here about it if you search it
Ya ive read it but lets say that what happened then why is there still fluid in the intake after i replaced everything with brand new gaskets?
So that picture appears that it's stained from dex cool which means there was coolant pooling on top of the intake. You said it was worse before so now you took it apart after the gasket were changed and there's no coolant I'd say you got extremely lucky and you probably have been burning coolant just not enough to realize
Well then i guess im lucky and will be happy to throw away this l36 intake for my l67 intake lol
Well lucky as in the gasket didn't Completely give way and fill your cylinder up with coolant and hydro lock like mine did but you have been burning coolant and that's not good the shop showed me the crank bearings out of my motor and when you have even little amounts of coolant in the motor like that when you shut the motor off the coolant pools in between the crank and bearings when it sits corrosion happens it eats the bearings and I had major water spots on the bearings or pits just so ya know
