Some more top swap questions! Yay!
Not tuning for methanol is one strategy some people follow because in the event of a methanol pump failure your afr is still the same
Do we put copper spray on a felpro head gasket? What thread locker should i use on the head bolts?
Sent from my LG-D851 using Tapatalk
Ok i just didnt know if the stuff on the bolts was good enough. There isnt anything else i need to know about the head gasket is there? Rtv in the corners or anything?
i did the copper spray on both sides of the felpro head gaskets.
make sure you clean the head bolt threads with a thread chaser.
Theres supposed to be 3???!!... Haha i got it but these are the right ones? I still need to get washers they only had little baby ones at the store. Also i got my dads puller but he has the recessed fitting on it instead of the cone shaped one is that a problem?
I shall do that once i get home ill take a pic of my puller in a little but i already fit it and the bolts slip through i did get the baby washers and they kinda fit but only if you angle perfect cause if the washer goes in even slightly off center then itll slip through too
