So..... The gtp has died... =[
You didn't try filling the silencer ports did you?
I've heard if those aren't done perfect they can come off and get into the engine.
pick up a shortblock out of a GT, slap a cam in it while its out, and slap the blower on it..and BAM! you have a stout DD.
update guys my dad is at work but he was talking to his buddy and thinks maybe the supercharger locked up and a gear inside sheered or something...? whatever we will figure it out tonight
take the belt off of the sc and see if it will run.........no need to pull the motor if it is fine......
if the blower locked up....the belt would squeel as the motor would still be turning over.
If he heard a big pop.... my "guess" is timing chain problems........
u prolly had low oil or something, not enough oil on the cylinder and locking your piston in place, Ive done that before with a different car. As it was said, pull the passenger wheel off and try cranking it over by hand. Get a L36 block, its soo much better for s/c, and they're cheap :D
I highly doubt it has anything to do with the s/c.
Get that pan off joe! Doesnt matter how u go about it but thats the first thing u really need to do. or take your oil filter off an cut it open. it its full of grey an shiny stuff u have big problems.
yeah guys i know i took the belt off and the pulley it freely spins so its not gen 3 related =[ i was hoping so lol but yeah its in the lower half on the block im sure. we will know tonight guys and at around 11 ill update all of you thanks for all your concerns and possible solutions. all is appreciated. but i am wondering if i that the lower mount out to get the rest of the pan bolts out how the hell do i keep the engine from not falling? ha
joe in order to take that mount out you need an engine hoist or some other means to lift the engine up so that u can unbolt the mount an get it out of the way. i ended up taking the whole mount off. the rubber part and the metal bracket. the brackets a B**** ur gonna need to squeeze a 15mm wrench in there. theres 5 bolts that hold it on. when i went back together with it i intentionally left the 5th bolt out because its in a terrible spot an 1 bolt missing from that brackets not gonna make a diff.
