Simple Intake (pictures)
the one side of the elbow is 4 inch o/d the other side is 3 inches.
see how one side is fatter on the elbow.
i see. but if i get those exact products shown, my intake will fall off pretty easily? if so what are the correct types i should get to prevent my intake from falling off over time
Mine is done with those exact products and only time it comes off is when I take it off.
Sent from my iPhail
the only thing you may want to change is the hose clamps that come with the rubber coupler and get 2 new ones from a auto parts store.
My 98 has the overflow bottle behind the drivers headlight and the pcm is zip tied vertically to that lol sucks cause I have a 9 inch filter...
Thanks newarkk, I finally got mine done. I hope the image uploaded because im having a really hard time figuring out how to do it. It keeps telling me files are too large evn tho im doing it thru photoshop.
Mine is a 2006..Also idk if I can mount the iat sensor in the pvc piping because then its before the maf sensor. Pardon my stupid queation but I didnt know if thatd be an issue because on the stock intake it was maf then the iat. My cone is a 4 inch so I couldn't switch them ariund as far as tb size and maf size. This is the only way it would work.
Thats because you need to copy the IMG CODE and then paste it with your reply no need to attach anything. your pic will show up just fine. As far as your IAT sensor it dosent matter post or pre maf but ideally youd want it close to the cone filter so it has the coldest air moving over it.
