PWNED
I have a dynotech Stage 2 Transmission. I really like it and since day one its been fantastic. Now with 15k on it I am not sure if there is an issue. Under WOT it shifts quick/firm the way i like it. Now coming from a stop under light load it goes into 2nd quick and firm and i like that. Now when it goes into 3rd its almost like a bang type shift. 15% throttle and below its pretty bad. 15% seems to be its worst At around 30% it will almost go away but you can still tell its there and not right. Now I put my shift times back to stock and pressures back to stock and it still did it. So i put them back to what i had them and there was no change. Its a DHP file i am pretty sure i got from a local member. Now I remember my stock transmission used to do the same thing but it was almost as if it was a band type feel slapping something. With my dynotech its more pronownced. Occasiaonally it wont do it at all.
I posted my BIN on the Powertuner forum if that would help at all.
Board Message
I decided to try it it again with a reflash. All the base shift pressures and times are stock. The performance shift times and pressures are DHP or zzp. Well the car does not shift as firm as it used too anymore in any gear. So no more of the 3rd gear issue. It still does chirp 2nd at wot so thats good in perf shift. The shifts feel exactly the same w/ perf shift on or off around town. I did not go wot at all with perf shift off. Maybe its a bad program? Makes no sense because perf shift is untouched from the previous BIN and it doesnt shift very firm.
Board Message
