This sale is for a set of 6 good used factory 36 Lbs. flow fuel injectors. These will fit GM 3.8 / 3800 series III L32 supercharged engines.
The part number is 12574393. These are the blue / gray in color.
if you mis calculated the injectors to a higher rate you shouldnt be pulling a lean condition code
so a injector that flows less than what the computer is set for could cause a lean condtion
