but yeah seriously, MAP, Boost controller MAP, FPR should be on their own circuit, small dia hardlines for instant response to pressure changes and should be plumbed to the most common part of the plenum (usually farthest from TB)
large brake booster should be plumbed to plenum by itself, heavily reinforced hose/hardline ~ 1/2" dia, if your using 1/4" npt hardware to make something, pay attention to the ID sizes, not all fittings are open to the same dia as the id of the booster vac check valve
plumbed to the plenum near the map/fpr stuff should be the lines feeding your mechanical boost gauge 1/8" plastic line, emissions solenoids, HVAC (older cars) BOV and maybe a mech boost controller (regulator/restrictor), maybe even for boost controller solenoids (if running single/dual solenoids id run that by itself to prevent issues with the pressure fed to the underside of the WG (pressure fluctuations would be affecting both sides of your wg diaphragm)
tying in the map with everything can mean that mechanical actuator latency is going to average the pressure seen by critical EFI sensors, making transitional tuning/event very difficult to get right
