Seafoamed my car today and TP code came up?
Was just wondering if these two things were related? Literally right after I seafoamed the car and took it out to burn through the carbon the car threw a code, scanned it and it was TP. Could the seafoamed have cause this im not sure if the two things are related but would love to learn about it.
This was my 97 GTP, I did also take the front passenger side wheel off to make sure I wasnt leaking brake fluid as my levels seems to be dropping at a very low pace and I though I saw some oil drips in that area of my drive way.
I have seafoamed my 97 GTP without issue.. I have also helped a few other people do their GPs with no problem. Reset the code and see if it comes back.
well without knowing your scanner.... I can just tell you if you pull the code there should be a reset/clear button.
I have one very similar. After it connects to your car, it will show you the codes. When you look through all them press the red button. The upper left one. Follow the prompts and it will clear your codes.
It was the TP code cant remember it off the top of my head but after I installed my new head unit today and took it out the SES light was gone? I will run the scan again in the AM..
Is that scanner not a very good one?
You can get one with the same features for way cheaper I got mine for $80 off amazon. Tp is throttle position sensor then?
