PALMCASTER GT1
I hear alot about this stuff but have never used it , what is it suppose to do and does it really work ??? And how are you suppose to use it ??
For the EGR, I recommend removing it and soaking it for a day with penetrating oil. Just costs you the penetrating oil and an EGR gasket will no ill effects.Regal - As far as I can tell, the individual I purchased the car from did an okay job maintaining the car. The left the ERG issue alone (was throwing a code for ERG valve stuck open) for several months. So there was some carbon build up around the ERG mount and the spark plugs have a bit of carbon built up on them as well.
The T vacuum line so it's past the supercharger.So should i run it through the T vacuum line under the supercharger snout? Or the middle vacuum line on top of it?
