RussDinoGuy's 02 GT "Slowkar" Less Slow Now
Re: RussDinoGuy's 02 GT "Slowkar" (RETROS ARE ON)
Isnt stock 2.5"? I honestly dont know... I have never given a **** enough to research it. LOL.
Stock is 2.25 iirc
And 01+ has more than 02 codes. They have cat diagnostics that make it run rich until it sees different readings from the cat. There was a thread about it
Stock is 2.25 iirc
You can correct Cat Diagnostics by adjust the way the codes report in the tune.
Yeah if you set it to report but not illuminate the cel or something like that. For a while it seemed unavoidable and was always talked about when modding 01+. Apparently its easy to avoid as long as you tune.
I have ZZP's 2.5 cat-less DP and I have no issues. I think 3" would be overkill for N/A but if you are doing ER rockers with springs, HV3 and Plog, a 3" would probably be ideal. Headers would be too much flow for N/A but might be ok as well for the mods listed previously.
Well I'll be putting on KYB drop in strut assemblys all around before the month is over. Ordered the rears and my LIM, UIM, and engine and trans mounts friday so soon as the struts come in and it a warm day I'll start putting them on. Also bought some Impala caliper brackets for 12" brake upgrade, I just have to wait till the end of the month before i can get rotors and pads for front and back I'm probably going to go with powerstops crossdrilled and slotted kits with pads combo. Then i need to find a weekend and plan a trip to ohio so i can visit some friends and get my LIM and mounts done and hv3 installed. THEN look for a 2.5" DP on the cheaps.
Screw the 12" brake upgrade. I would advise you to install dual piston calipers. Just do the LIM, mounts and HV3 yourself. It's easy.
Also Bill knows a member on here who still may have a 3" ZZP DP for sale
Meh i already bought the brackets so I'll just run them. As for the mounts i probably could do myself but the LIM I'd rather have help on. Plus its a good excuse to go visit captnslowregal i mean captnbreakalot.
If your going to go through all that work at least go Impala or Fbody.. After all the only thing you've purchased was the bracket so no huge lost.
Exactly.
Just return the brackets if you can.
Guy sent them out yesterday so I'll just run them I know fbody or impailers are better but I'm due for new brakes anyway mine are scary.
These are so dirty
Last strut came, now i need too decide if i want to wait and do my brakes at the same time. Anyone know what size tubing fits over the bleeders?
Put anti-pogo washer on while you have them off the car, they help even with stock springs. No idea on the bleeder, I think I used fish tank air hose once, lol.
OKAY so after many a snapped bolts and runs too the part store i have everything done.
-cleaned MAF
-new air filter
-flushed brake fluid (old was green eww)
-brakes all around with 12" upgrade in the front
-KYB drop in assemblys all around
-new napa reman axles
All in all i could have knocked it out in a day without all the setbacks. Now sit back and enjoy the pics. I still need to break in the brakes, top off trans fluid and grt an alignment.
Day 1 getting rear strut bolts loose and cutting my knuckles up
Nasty fluid
rear done
This is why my brakes sucked....
Me at 6am getting the axle out
guide bolt I snapped because it was seized
The axle I accidently ripped in 2, notice the missing grease. It was all thrown up on the subframe, had been like that for at least 35kish
Didn't know a decent amount of ATF would come out of the passanger side....
new and ready too go in, these were cake a simple "smack" from a hammer on a pry bar and they came right out.
Bleeding the brakes/flushing the lines with new fluid
all done plus 12" rotor upgrade
New air filter
and 4x4!!!!!
Also I only dropped my wheels on the face of them twice, ffs I'm a tard.
Re: RussDinoGuy's 02 GT "Slowkar" (NOW WITH LESS BROKEN SHTUFF)
In for an alignment and tire rotation right now. My god it rides like a totally different car and these brakes are awesome. They make a humming noise under braking but i really don't care. After i got the last of the air out of the system the pedal is nice and firm now. Still have a clunkish noise from the front end on the dirt roads but im thinking subframe bushings or sway bar bushings.
