Re: RussDinoGuy's 02 GT "Slowkar" (RETROS ARE ON)
why on gawds green earth would you get a 2.5" DP?
Because N/A powahwhy on gawds green earth would you get a 2.5" DP?
Stock is 2.25 iirc
And 01+ has more than 02 codes. They have cat diagnostics that make it run rich until it sees different readings from the cat. There was a thread about it
Well I'll be putting on KYB drop in strut assemblys all around before the month is over. Ordered the rears and my LIM, UIM, and engine and trans mounts friday so soon as the struts come in and it a warm day I'll start putting them on. Also bought some Impala caliper brackets for 12" brake upgrade, I just have to wait till the end of the month before i can get rotors and pads for front and back I'm probably going to go with powerstops crossdrilled and slotted kits with pads combo. Then i need to find a weekend and plan a trip to ohio so i can visit some friends and get my LIM and mounts done and hv3 installed. THEN look for a 2.5" DP on the cheaps.
Exactly.If your going to go through all that work at least go Impala or Fbody.. After all the only thing you've purchased was the bracket so no huge lost.
