cleangtp
Banned
Looks good. What kind of paint did you use on the reflectors?
The housing was black, when wiping the inside of the housing clean the chrome actually wiped off. It didn't look good so I got some high temp black regular spray paint. The headlights here are from zonk speed or something like that on ebay. They're rushed from the factory. Minimal silicone where it needs it most.
I actually got the car back from getting fixed from a deer. I had the GTX hood put on at that time. When I picked the car up from the body shop the headlights had moisture the first day. Here's some differences below on these housings.
The silicone on the right is from the factory very sloppy. On the left you can see where I sealed the actual corner of the housing. That's quite a bit of silicone to get it to look light that. I also went around the top, bottom, and other corner. Black corners that don't leak for the win.
Here, you can see right down inside there's no sealant whatsoever. Headlights are the same way but not after I get done with them.
