retro fit
Looks good. What kind of paint did you use on the reflectors?
The housing was black, when wiping the inside of the housing clean the chrome actually wiped off. It didn't look good so I got some high temp black regular spray paint. The headlights here are from zonk speed or something like that on ebay. They're rushed from the factory. Minimal silicone where it needs it most.
I actually got the car back from getting fixed from a deer. I had the GTX hood put on at that time. When I picked the car up from the body shop the headlights had moisture the first day. Here's some differences below on these housings.
The silicone on the right is from the factory very sloppy. On the left you can see where I sealed the actual corner of the housing. That's quite a bit of silicone to get it to look light that. I also went around the top, bottom, and other corner. Black corners that don't leak for the win.
Here, you can see right down inside there's no sealant whatsoever. Headlights are the same way but not after I get done with them.
those look niceeeee my projectors are back ordered :(
What do you mean back ordered, from where? I have an extra Morimoto projector H1 that I'll sell for cheap. The bi-xenon solenoid was mounted 1/4 inch past the bottom of the housing. I dremeled the top of the projector housing to make it work but couldn't get it to sit flat. I contacted Retrofitsource.com and it was a factory defect. You could make it work by grinding the bottom inside headlight housing where it sits but I just bought another one. TRS would've taken it back but I grinded the top corners. You can have it for $30 shipped if ya want it :th_biggrin2:
You are buying Morimoto projectors right?
backordered at TRS......blahh
can i haz plz? :D
I've got another set of black retro's that you could buy if you want them. They're not the greatest because they were my first set I ever did. They're just sitting here, pretty much look exactly like these.
How much money you haz?:th_biggrin2:
You pay for the projectors, shrouds, and oem black housings plus give me half what I'd normally charge for labor and I sell them to you!
i already have everything ordered and on the way.....just waiting on TRS to ship my proj and gunmetal shrouds
Junki what did you select for the relay in the drop down box? Clean do you know if it would be possible to remove the projector in a spyder housing and replace it with a Mini Morimoto?
I wouldn't attempt it probably be pretty hard to mount if you even could. Plus I think peeling the lenses on spyders isn't an easy task from what I've researched.
hmmm...thats lame cuz i dont like the look of the single projector in stock style housings...and theres no spot for a second one
Here's the black housed I just got done with. I'm keeping them :th_biggrin2: bolted them up and adjusted nothing. You think you can replicate a perfect cutoff like that Junkie :th_nanana:
Don't mind the narrow garage or all the stuf in the way. I'll get some more output pics on a building sometime soon. I didn't even have to touch the adjusters and that's just low beam!!! Taken from a 2 megapixel blackberry.
im gonna do my best im anal so mine will be perfect before i consider them done
get the 9007 bi xenon harness.....although v-leds.com has one on sale for 12.99 right now :)
same quality
so then its all plug and play? also whats the difference between the H1 and the D2S kit? Just the bulbs?
