SgtMarshal
Active member
I have PE set to 30%, can't do a screenshot now, but if I remember later I will message it to you on facebook
But 11.8 isn't lean?
Sent from my LG-H918 using Tapatalk
My PE is enabled at 30% throttle between 0-3600 rpm and then its at 25% from 4000-6400. The 25% is kind of low because driving on the highway just trying to simply pass someone its really easy to slip into pe but for me I was always seeing blips of kr when I would mash the throttle especially at high way cruising and lowering it to 25% helped the extra fuel kick in faster and I was able to get rid of that kr.Curious, for both you and suitercrew, at what throttle position is PE mode enabled on your build? Mind sending a screen shot of your PE enable table?
Well I got my afr down to 11.1-11.5 but now I'm seeing a little blip of kr at the shifts so ill probably just pull down to 21* timing and leave my afr there. I thought 12 afr were way to lean? How much power are you actually picking up leaning it out that much.Not on corn it's not. North of mid 12's dipping into the 13's I'd say is about as lean as you'll ever need to go.
DhpYou using hysteresis?
You know what I was always curious of is like I have 22* timing right now but if you look in the tune itself its set more at the 19-20 range. I thought there was some multiplier table or table that added timing advance kind of like the iat table but I can't find any so why is there a difference in the actual spark advance and the spark advance in the tune? Also whats the mean best torque spark table magigy?you can change the pe settings, how much fuel you get when in pe mode and such.
Idk I really like how the car is running right now but I will have to knock the timing down probably to 20 since I leaned it out. The cars just so much more responsive with high timing imosay your bottom row of timing is set to 11's in the higher rpm's, that will show as 5 to 6 more on a scan, so 11 is more like 16-17
you could grab some 04 comp g timing and load that up. its a more aggressive timing for sure. its what im running now, but ive got it tuned down some up top.
Ya I have no idea how to even use tiny. I just make educated guesses take it for a scan and repeat.Tuning without dhp/tiny is about as much fun as slamming a car door on yer pecker
Ya your probably right 500$ isn't that much. I just need to also continue saving for a transmissionI was looking at the tiny tuner, at the PE hysteresis, I couldn't see any way to use it.
Jon, you will be better off just saving up and buying the HP Tuner new, good deals on used ones don't pop up very often, and when they do, sometimes they have no credits so you end up spending more to buy credits. A new HP Tuner has enough credits for 4 vehicles, and even though you think you will only need credits for 1, I know cause I did, I've now unlocked 3 different vehicles.
