Do I need one of these for my 2000 GTP? Want to delete cat but not lose MPG.So I just found this on ZZP - Angled O2 bung #
FYI I read the entire thread so I missed it. Thanks for the help.Actually reading the thread helps a lot. ;-)
97-00 doesnt care about the rear o2 sensor for fueling. 01+ have the cat diag in the PCM that when the cat and rear o2 are removed will effect gas mileage.
On 01+ the cat can always be removed, but will require a tuner to shut off the diag and the code, the 97-00 will just need a tune to shut off the code and stop the SES from coming on.
Uh no..... you will run rich as hell Because the test comes up incomplete. It will then try to richen up the mixture in order to keep the cat from being burned upThe solution to this is just to remove the cat but not the two sensors so that the ECU will run the diagnostic process and it'll fail but the ECU will not report the code. Since the diagnostic sequence will run and then fail the ECU will not continue to run the diagnostic test which in turn will result in no excess fuel being used once said test is ran. Fuel is only wasted if that test is continued with no definitive result to be recorded as a pass or fail by the ECU. Like FFDP said the diagnostic procedure and cat codes will need to be turned off by someone with HPTuners.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Just saw youre response dude you never said you had HP tuners and that it was already taken care of my post was regarding If you were on a factory calibration still and removed the cat while leaving the rear 02 activeI decided to take a look with my torque obd2 app on my android phone because I haven't had time to grab my laptop and catalyst emissions check has been completed (while I have known that this emissions check has been completed I wanted to show you proof anyways so that people know that it does not show as incomplete). Please note that my cat is removed. So There's proof right there that the catalyst emissions check is able to complete as long as everything is set up in the ECU correctly with HP Tuners
I have an 02 GTP.
Going with TOG headers and TOG stainless 3" with cat. Tuned PCM with Cat codes, rear o2 sensor codes, and egr codes all removed etc...
Is it beneficial to run an o2 emulator to keep my fuel trims? Or do I need the real rear o2 sensor to not run flat out rich?
I tried reading through all 9 pages and deciphering the correct information but still didnt come to a conclusion.
Tiny tuner shuts test off.
I did not know that where can I get tiny tuner?
I have read through all 9 pages of this damn thread 3 times now. i am not sure of the answer to my question STILL. i bought an 01 GTP, the cat has been removed, i have a P0420 code, thats it.
