Rear strut/springs
danwilson1959
I have a 2000 GTP and I'm changing out the struts and I'm have trouble getting the top bolt out where the strut bolts on the what I call the knuckle. Is there a trick to getting this out? the bottom bolt popped right out when I hit it with a hammer.
I used an air punch with blunt end after threading the nut on to cover and protect the threads. A heavy hammer also works good.
Just to clarify, if you've already got the car up on jack stands, put your hydraulic jack under the knuckle or ball joint and take it up just a tiny bit - you're just trying to lift the weight off of that bolt. Once you've relieved some of the weight, bang away and the bolt should pop out easier.
I had this same problem doing one of my struts. I took the top one out first one the other side and had zero problems. If you can find something that grips it without stripping it then turn it like a screw. I was only able to get mine so far with a hammer then had to do that to get it the rest of the way.
I don't understand why everyone has problems with that bolt, even on my dads car all rusted to hell I hit the bolt and it flew out and hit the fender liner.
Sent from the Milky Way
I Agree. I've never had this problem and I've worked on many w-body struts. Just use a BFH and you should be good
Thanks everyone. I ended up cutting the head off and using an impact to pull the bolt through the other side. Going to tackle the front pair this week.
