Scott afaik the l67 and l36 heads are 100% the same minus the injector bungs. So they flow the same.not the same. your l36 is high compression, where the l67 is lower. you dont have l67 heads either, another restriction i guess.
and because of the higher compression. and we cant run the same timing as a l67 can. our timing is lower.
when you rev the engine from under the hood, does the lever on the bbv move?
This sounds strangely familiar...... If zzp programmed the computer then they must have basically set tables for running the thing as a speed density system above atmospheric pressure, since a 1 bar map will only read to atmospheric. The output of a map sensor is 0-5V, a 1 bar is close to 0 at full vacuum (about 29"Hg) to 5v at atmospheric (0"Hg/0psi) a 2 bar MAP reads 2.5V at atmospheric pressure and goes up to 5V, at 14.7 psi or so (correct me if I am wrong, please). So basically after you reach atmosphere pressure or 0psi the PCM can no longer "see" any boost and would have to refer to preset tables based on airflow and SD or strictly Speed Density, but then again how can it when it doesn't have a good signal from the MAP.
The higher compression is from the pistons.Yes the bbv does move and it whines real loud. Yea I think the higher compression is from the heads so I've heard like a 3.4 pulley on my setup is like a 3.2 or 3.3 on a gtp so it should be higher?
that is exactly true. a boost gauge only reads what the sensor says, and a 1 bar sensor is going to say very little. I doubt there is a single car company in existence today that uses a 1 bar map sensor.
that baro is 04 up crap jeff.
Most of them die within a year, but that is also on a car that is used daily so they might a little longer if you haven't put that many miles on them, and yes the stock coils were even tested by ZZP to be better than the MSD ones, its actually on their list of things that you shouldn't replace. I'll have to dig up the link for that.Thanks man yea EVERYTHING in the motor is brand new only has 5,000 on it thats two summers of me driving lol. Are the msd coils that junk? I just find it hard to put old stock ones on when those are like new. Here are some more pics this is how zzp told me to set it up.
http://i300.photobucket.com/albums/nn39/brandontonkin2/20150816_213027_zpsqfcalpq5.jpg
http://i300.photobucket.com/albums/nn39/brandontonkin2/20150816_213054_zpsixfnrmyn.jpg
