Question about how much boost I'm running?
Yea my bad... Does that sound about right though? I was hoping for at least 10 that's why I'm asking. I am running 0 KR on this setup. I plan on pulling the motor back apart this winter though going with xp cam, ls7 lifters, 7.00 comp push rods, double roller, 140lb valve springs, with a 3.1 pulley.
with only 6 psi boost i hope not lol im top swapped too with lightly ported heads 1.05 roller rockers, sd headers and a stock pulley that see's 6.5 boost. with the 3.4 on there i was @ 8 psi part throttle and kr out the ass, so it had to go.
im really bottom swapped, my car came with a l67 and it took a crap. so i used a l36 bottom end.
and you need a ic to run that pulley. 3.4 is pretty much the wall with out a ic, or e85.
not the same. your l36 is high compression, where the l67 is lower. you dont have l67 heads either, another restriction i guess.
and because of the higher compression. and we cant run the same timing as a l67 can. our timing is lower.
when you rev the engine from under the hood, does the lever on the bbv move?
a 1 bar map sensor isn't going to give an accurate enough reading for the pcm to compensate for higher manifold absolute pressure readings. most cars these days will use 2 bar map sensors because 1 bar map's are old technology.
I wouldn't bother changing pushrods unless you need a different length. you aren't going to get more performance out of a different set of pushrods. I would do the 130 lb valve springs instead of the 140's because you want to run the lightest spring to get the job done, and 130 is good for the xp cam. even with that upgraded harmonic balancer you got from zzp, I wouldn't rev that thing higher than 6300 because it isn't going to reduce vibration enough to go much higher. you will get a lot more out of your build if you do a set of ported heads with that xp cam, I recommend the ones that orangeL67 does on here, he doesn't charge near as much as zzp and you get a better product.
as far as boost goes, more is not always better. boost from a supercharger increases the pressure inside the engine, so having low amounts of boost means you have the flow mods set up the way you should. I would do the 2 bar map sensor, and get the tune adjusted, I'm not real sure what would need to be changed, but after that happens if you still have low boost, you might be able to pulley down and then scan for kr
Yes the bbv does move and it whines real loud. Yea I think the higher compression is from the heads so I've heard like a 3.4 pulley on my setup is like a 3.2 or 3.3 on a gtp so it should be higher?
Yea I'm not really worried about the map I have a mechanical boost gauge hooked up. Zzp has it reving to about 6400 right now they said it's benificial to rev higher but not till i put heavier valve springs in. My heads are ported already and they said 7.00 push rods will get me to the happy place with a ls7 lifter stock is 7.05.
some thing like that. i built boost so fast with the 3.4 on this set up now. i light footed around town for 2 weeks waiting for a puller lol
its got to be the map not reading right, its sounds like your making full boost if you hear the sc screaming. does it feel like its pulling strong and hard? it should if your making full boost.
you dont under stand the map. your sucks, the pcm cant read it well. why you need the 2 bar map wired in. you just cut the wires and solder on a new pig tail on and use the new map.
Yea it pulls strong I just want more hp you can never have to much. How is my map reading wrong when I'm reading it from my mechanical boost gauge I plumed in?
a mechanical boost gauge and a map sensor are totally different. the pcm is going to use the map sensor to operate the engine. the boost gauge only shows you what is happening inside the engine. you really need to study how an engine works to understand why the different length pushrods are not necessary unless you take measurements and see that you need them. LS7 lifters are about the same length as oem lifters so most people don't change pushrods.
it really seems that you believe everything zzp says without any question. you need to learn more about engines because everything zzp says may be true in some cases, but not entirely.
Yea I understand how an engine works I built this myself.... I just thought the boost seemed a little low. Ls7 lifters have a tighter range then stock so you need to find the happy medium. Yes I do believe zzp haven't had a problem yet why wouldn't I go with them?????
lord help you man. zzp sucks a dick on there info, most of it is bull sh it just so you buy parts. its what they do, sell parts you know.
I was just going to put a L67 map on it but they told me I will need a pcm flash. I wanted a mechanical boost gauge anyways they said it would be easier to just go that route since its my summer daily and id have to wait. I haven't had many issues with zzp and when I did they made it right they do good work i don't know why everyone has to get so hostile and hates zzp I'm just talking? I wanted others opinions that's why I joined the forum everyone on seems to get computer tough guy with me for no reason?
This sounds strangely familiar...... If zzp programmed the computer then they must have basically set tables for running the thing as a speed density system above atmospheric pressure, since a 1 bar map will only read to atmospheric. The output of a map sensor is 0-5V, a 1 bar is close to 0 at full vacuum (about 29"Hg) to 5v at atmospheric (0"Hg/0psi) a 2 bar MAP reads 2.5V at atmospheric pressure and goes up to 5V, at 14.7 psi or so (correct me if I am wrong, please). So basically after you reach atmosphere pressure or 0psi the PCM can no longer "see" any boost and would have to refer to preset tables based on airflow and SD or strictly Speed Density, but then again how can it when it doesn't have a good signal from the MAP.
