Today i've become a man
I guess this confirms where the coolant leak was
I did notice these plastic spacers on some of the front cover bolts
Most of them are eaten away, do I need to worry about replacing these?
And of course when pushing this thing into my garage the freakin wheel comes off. Almost pooped myself because I thought the entire engine was coming down.
Ok some questions, I need a final answer on the TQ spec on the rear cover, when I google I see a listing for ""Crankshaft Rear Oil Seal Housing" that lists "15 + 50?Nm". Being it has question marks and all that makes me question it. And that's a huge number, it would be a total of 65Nm which sounds tight to me. Second question I asked above, whats up with them plastic spacers on the rear cover bolts? Should I remove what's left of the plastic on them? For parts cleaning, I was thinking of getting a big plastic tub from Walmart and 5 gallons of Kerosene (Cheapest solvent I can get in bulk I think) and soaking the oil pan, valve covers, and rear cover in it. Will that hurt anything? The oil pan has a sensor on it, should I take that out before doing this? And last question for now, anything else besides the oil pan gasket, valve cover gasket, rear cover gasket, should I change while the engine is out? I'm also slapping some spark plugs in it since that rear bank is not easy to get too.
Thanks guys, without you I would of just towed the car to the junkyard. Now it will live again!
